For the 3.5s, the OEM tire is 215/55/17. The speedo is set to that specific tire size. Any bigger, then the speedo will reader slower than your actual speed. Any smaller then the speedo will read faster. If you decide on 18s, the optimal tire would be 235/45/18. I was running 225/45/18 and got a deal on 225/40/18s. There is an 1inch (1/2 an inch on each side) difference in diameter between the tires. Half an inch may not sound a lot but when your car is only 2 3/4" from the ground, 1/2" makes all the difference in the world!sjbaltimaproject wrote:So ive been wanting to get 20's for my a/c but found a good deal on 18 tenzo rims so i might do that instead to save money. the only thing im not sure about is the tire size. i was thinkin of getting 225/40/18 but idk if that would cause any issues with things like the odometer reading alot more miles than i actually travel? can i get that reset at the dealership? I used the calculator that mhendi found and it said it was a -4.1% difference? do you guys think it would just be better to stick to getting 20's ?
Infinite-T wrote:Hey Bro,
Check out http://www.elementwheels.com/proddetail ... pemv2188bm
I was looking at those same exact wheels, this place says they will sell a set of 4 for under 900. and they can put any tires you want on them. Buying from a shop like this might be safer then buying on ebay too.
