Tires are rubbing
General discussion area for the L32-chassis Altima
herc0550
Car: 09 altima sedan (dark slate)
i jus got some 19s on a 09 sedan. when i drive by myself its straight but when i have people in the car i start rubbing in the back. has anyone experienced the same thing? do i have to roll the fender? i was thinking of droppping it 2 inches all around but i dont want to rub. any suggestions?
malnevets
Car: 07 Altima Majestic Blue
so the tires are rubbing with people in the back even without a drop?it could be the fenders, or the offsets are off.
do you know where the rubbing is happening? inside or outside tires.
Id fix the rubbing problem b 4 considering a drop.
ArtistikD42
Car: 2008 Nissan Altima
how big are your tires?
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
It could be a few things...your offset is incorrect, your tires aren't sized correct and/or your wheels are to wide. My guess is it's and offset and/or wheel width issue. You should've have to roll your fenders to fit 19" wheels on and '09 Altima.
herc0550
i have 235/35/19. n i think its 8.5 width or sum s*** like dat. and its the putside of the tires dat are rubbing when it sort of starts tucking in is where it rubs
beeristasty
Car: 07 Altima 3.5 SE
soundz like yer rurr offset is wak. rollin yer fendurrs mite hellp.
Flores45
Car: 07 Nissan Altima Sedan 2.5
herc0550 wrote:i have 235/35/19. n i think its 8.5 width or sum s*** like dat. and its the putside of the tires dat are rubbing when it sort of starts tucking in is where it rubs
Yea sounds like your offset is off
beeristasty wrote:soundz like yer rurr offset is wak. rollin yer fendurrs mite hellp.
lol
belo2012
Car: 2009 Nissan Altima 3.5 SL
what would be the correct offset....because i am looking to get 19" 9 in the front and 9.5 in the back and i was planning on doing tires 235/40/19 or 245/40/19.....would that also be a problem. whats the perfect fit?
herc0550
so i have a 235/35/19 with a 9 inch width. whats the ideal offset? i stopped rubbing because i rolled the fender. but why do you think my steering wheel is shakling?
beeristasty
herc0550 wrote:so i have a 235/35/19 with a 9 inch width. whats the ideal offset? i stopped rubbing because i rolled the fender. but why do you think my steering wheel is shakling?
One (or more) of your tires may be out of balance.
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
depends where you're rubbing. most likely your offset is too low based on your profile pic, looks like your wheels are sticking out too much so you would need a higher offset. if you look at your fender and the rubbin is coming from the outside of the tire, then you need higher offset. if the rubbing is on the inside, then you need lower which means you can just get spacers.
and your steering wheel is probably shaking cause either your wheel(s) are off balance or you may need an alignment
mmx23z
Car: 2008 A/C 2.5s CVT
herc0550 wrote:i jus got some 19s on a 09 sedan. when i drive by myself its straight but when i have people in the car i start rubbing in the back. has anyone experienced the same thing? do i have to roll the fender? i was thinking of droppping it 2 inches all around but i dont want to rub. any suggestions?
slap some of these stickers on lmao :rotflmao
frankenberrie
Car: 2010 Altima Sedan 2.5s+Convenience Package
Holy crap... those stickers are great. My pops owns a graphic design shop and makes vehicle graphics.. I'm gonna have him whoop me up a batch
blue bastard
Car: 2008 nissan altima sedan
i just had 20s put on not to long ago and any 1 more person than myself would cause my tires to rub they are 8.5s and ever since i got my fenders rolled no more problems no matter how many people were in the car . Rolling the fenders probly your best bet if you like your rims ad its pretty inexpensive too i think i paid round 150.
07WinterFrost 3.5 SE
Car: 2007 Nissan Altima 3.5 SE
I run 19s with 8.5 width and no rubbing at all dropped with Eibach pro kit. My offset is 35mm
JPs VQ35
yo OP you sent me a PM about my 20s. I cannot reply due to your settings disabling PM's from others.Judging by the looks of it though, a trade is highly unlikely. My rims are on 245/35ZR/20 with a 38mm offset, they are 8.5 as well. Rub lightly but only under load and on hard curves.Disable PM issue with your Profile if you want to continue with the Wheels Stuff.
jamesjohn012
I think you are tires are out of balance or incorrect size. Once check and fit the perfect one.
98blackbell
Car: 1995 Nissan 240SX SR20DET(STOLEN)
1993 Nissan 300ZX 2+2
2006 G35 Coupe
1998 Chevy Tahoe 2DR 5.7
1975 Datsun 260Z Turbo
what is the factory offset!
superbad
Car: 2014 alti 3.5SL
07WinterFrost 3.5 SE wrote:I run 19s with 8.5 width and no rubbing at all dropped with Eibach pro kit. My offset is 35mm
what size tires do you have, i just picked up rims same size and same offset. i eventually plan to lower.
Return to “4th Generation Altima Sedan (2007-2012)”
