tires and wheels
dmb2427
Car: 93 Nissan 240SX Conv.
Would I be able to fit 215/50/17 on a '93 240 vert.? I have found a great deal on the tires but am not sure if it would be to big.
chmercer
need much more info. what offset/width of the wheels. stock height? lowered?
but i would guess yes they would probably fit, not knowing any of your statistics.
dmb2427
the wheels are 17x7 and the car is going to be dropped about 1 inch
chmercer
offset? if it is very low you run the risk of hitting the fender. too high and you can rub on the strut. i am guessing these wheels are probably like +40 offset or somthing. id bet they would fit.
dmb2427
The wheels that I am looking at are these the Konig Next http://www.konigwheels.com/cat...d=324 and the tires are the DUNLOP SP Sport A2 215/50/17 Section Width: 215Aspect Ratio: 50Construction: RWheel Size: 17Index: 90HSidewall: BS I am just not sure that they will fit
