SanoSuKe »
https://forums.nicoclub.com/sanosuke-u193144.html
Sun Mar 09, 2014 7:00 pm
As much as I love low offsets.. if you plan on running a 10.5 width square setup then I recommend staying with the +30 offset. Especially that you mentioned before that you don't want any crazy stretch.
Let's say you do want to run the +20 offset, I would change the front tires to a 235/35 and the rears to a 245/35. Or keep the rears 255/35 but add minimal camber. My main concern is the front because there's little modification available for you to clear the wheels.
