nsrZ32 »
https://forums.nicoclub.com/nsrz32-u20984.html
Sun Dec 02, 2007 12:27 pm
Your brakes should be ok. Due to the soft compound of the tires if you drive with a heavy foot the rears will be starting to thin out. Have them check the tread depth for you. Also, they should perform a complimentary multi-point inspection where they check brakes and things of that sort.
