Tires: Advans
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
not getting any response int he 240 chat so i figured id link it here
zerothread/170503
Modified by drifter_for_life06 at 10:50 PM 4/19/2006
McRussellPants
Car: 92 240SX
Never used it...
Its an old compound. I bet the RT615 is better... and cheaper.
nismofly
Car: 89 Nissan 240SX Hatch
id say get them, you cant get falkens in 14s, and thats a good price
drifter_for_life06
Car: Daily: '16 WRX
Exocet
anyone got experience with this tire or any of the Ultra High Performance Advans?
nismofly
i dont on 32's i do on 48's and loved them, but like russell said theyre a much newer (re: better) design
i hope youre not planning to use these for anything but auto-x and track days, because theyll last probably about 800 miles on the street, these arent UHP, theyre R compound
youd probably be better off with like a toyo ra-1, seeing as you could get used to them because youd be able to run set after set instead of running 1 set and having to switch again
drifter_for_life06
Car: Daily: '16 WRX
Exocet
anyone know if i would have problems running a 205/60R14 on a Stanza wheel? The rim is 14, but is the 205 too larger?
nismofly
205 is width, not diameter
what size are the wheels, like 14x5.5 or 14x6?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
yes i know its width
edit: they are 14x6
Juujai
sure you can fit a 205. we fit 205s all day on 15x6 stock wheels. im not sure how big the sidewall should be though. 60 series sounds but but it is a 14".
i'd say if you're on a budget try the kumho or hankook r compound tires.
are you really sure you're ready for race tires anyway? in autox it'll toss you into a really competitive class.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
i decided against anything special since i need the tires asap
went to Sears and grabbed two Falken Ziex 512's instead. Should do fine for now on the street i guess ill wait for track wheels
nismofly
start on the track with something less than r comp advans, ill be running either kuhmo ecsta mx or falken rt615 this summer
youll be able to get used to your tires going away and stuff, its better experience
