I was just gonna do a duelly conversion with about -12 deg. of camber using two 18x14 -15 offset wheels with 185/60/13's on them.aither wrote:wait, so you are going to mount those on 11" +0 wheels up front and 12.5" -20 wheels in the rear, right? With something like -8 degrees of camber in the front and -10 in the rear? 3" fender pull?
If not, then, yes, we will give you a hard time.
Q45Tech said 1.1 G ... given enough traction.240sx2nr95 wrote:i wanna know wat it'll pull on the skidpad, 255 fronts wont be the problem... itll be the wheel itself, heh. i still love my 245's up front... rears will look SICK from behind. shouldnt have a problem fitting those either. Can't wait for pics.
-Dan
Here's the solution.. http://nicoclub.com/zerothread?id=90235Grant@tirerack wrote:Graham, your signature is messing with my head Now I want to go home and get some graph paper and try this on my friends. That is so cool!
Heheh... smart *** :Pcrzycav86 wrote:Duh.
My car can pull off 3 G, just like a f1 car.... given enough traction
It might be a possibility but then again those guys run on a bigger budget than I can afford. Just getting the car there would be difficult but I would love to do it.crzycav86 wrote:You know, you should enter your car into the USCC. It definitely seems to have the numbers to compete with the big boys and with 20k+ NICO members, getting voted in shouldnt be a problem either(especially with your reputation here) Have you ever thought about it? Yes... SCC is kinda gay, but winning the USCC would definitely be good for you.
One day you will be crack free... one day.ChunkiDori wrote:but the real question is... how high is the car going to be?
if you can see the top of the tire on 17" wheels, it's too damn high.i have a garage thrash under protect to save my oilpan from errant objects because my car is so damn low.it's awesome. but needs to be lowerframe rails need to scrape on road turtles. YES.
Should have found smaller quicker wearing better gripping tire!Nismo_Freak wrote:
Oh which there are very very very very very few that are able to be driven on the street.SmithSR wrote:Should have found smaller quicker wearing better gripping tire!
nm
in a perfect world...Nismo_Freak wrote:One day you will be crack free... one day.
