Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Mon Jan 14, 2008 8:08 am
I think the Bridgestone Potenzas (RE0050E) is the best. It is expensive, however. I have 16,000 miles on it with just a single rotation and the threads are still looking good. I think the tire will go 20,000 to 25,000 miles before replacement. I have a 2007 G-35 Coupe, 6MT, RAS, NAV, VLSD. I will be buying the same tires again. For a high performance car, 20,000 to 25,000 is excellent wear on a low profile tire.
Everything about the G in terms of maintenance is expensive. 4-wheel brake job at the dealership may set you back about $500 or more. OEM clutch replacement will set you back about $1,200 without fly-wheel replacement, if burn marks are not found. With fly-wheel replacement, you are looking at $2,000. The premium gas it uses alone is crazy expensive.
The G-35 is a car that requires specifics just as any other real sports car. Right now, I am changing the OEM filters every 10,000 miles. Alingments should be done every 15,000 miles. The oil recommended for use is a blend, which is about $1.00 to $1.50 per can above dyno oil. Most delaerships use Pennzoil 5w-30 blend. Avoid synthetic on the G-35 if you can. Engine was actually built with dyno oil in mind.
However, I have come to discover that the Pennzoil blend the dealerships use may not be a true blend. Recently changed oil and swithched to Castrol Syn Blend. Suddenly, my car feels awake, and the new oil change does not muffle the sound of the exhaust as the Pennzoil Blend does after a few days after oil change. Again, another sign of how the G-35 is sensitive to the type of oil you use. So, I suspect Pennzoil blend has more dyno oil in it than synthetic, while Catsrol Synblend seems to have more synthetic in it than dyno.
Just my 2 cents.
