SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Wed Feb 25, 2004 2:28 pm
They probably had a hard time mounting the tire on the wheel, because at that width, with that sidewall height, the tire's second bead doesn't just ease itself onto the wheel. They've got to do a little bit of work to get them on.
The tire should seat just fine. They were probably having trouble with one side of the top bead seating easily. They most likely had to inflate the tire to 50+ PSI to get both beads seated properly.... which is a no-no as far as the written rules are concerned.
The wheels can be cleaned very easily around the area where the tire's beads seat themselves. A wire brush and some elbow grease can make the bead mounting surface clean and nearly new in appearance.
