HAHA lear from any mistakes. Thanks for the vote of confidance Nate.Sentientbydesign wrote:Your arguments are great. I was just too lazy to back up my posts. I think if we did, we'd end up at a stalemate. Unfortunately, I'm not getting all I need to get done during the day, so spending time researching my POV sits on the bottom of the totem pole.
Please let Jerry continue on with this experiment. I think we can all benefit or learn from any mistakes and modify as needed.
I didn't mean mistakes that you made in your experiment. I meant improper pressures that cause wear. Obviously the experiment is going to show flaws in one method over another.awdjdmtalon wrote:
JerryWe all know you're a screw up, we all find that out when the milkman was confirmed as your Dad.awdjdmtalon wrote:
DOH!!! I don't know how I forgot, this was a whole topic earlier.awdjdmtalon wrote:Nate I was just playing. I know what you ment.
Liam. I don't think the temps have much to do w/ it. W/the nitrogen in the tires the pressure stays pretty even.
OMGosh! Is the G ok? Is it in full recovery lol. I assume you're recovering ok?awdjdmtalon wrote:I haven't gone another 1k miles yet. Car was parked for just over a week due to a surgery. But I will check them this week and see if there has been any changes.
Here is my post on the subject of tires.awdjdmtalon wrote:Ok I put new tires on my G last night. And as we all know, they like to wear the centers out of the rear tires. I think this is for several reasons. 1 is the tire is too wide for thewheel making the tire buldge in the center. 2 Is the tire pressure being to high for #1.
So what I have done is this.
1. Filled the rear tires to 32 psi.
2. Filled them w/ nitrogen. This will eliminate tire pressure fluctuation due to temprature.
3. Measured the tread depth in 3 location. 1 the outer rib, 2 in the center and 3 on the inner rib.
I am going to drive 200 miles and recheck pressure to make sure it is constant, and tread depth.
If the tire is wearing in the center, lower pressure 1 psi and repeat.
If the outer edges have worn more then the center, raise pressure 1 psi and repeat.
Keep doing this until I reach a pressure where the tires are not wearing either spot unevenly.
Now for the hard part. Trying to drive the car nicely for this experament. <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... aughty.gif" BORDER="0">
Modified by awdjdmtalon at 10:40 AM 9/19/2008
I typically get into the 60k+ area on a set of tires. As far as experiment to measure contact patch it seems to me this could be done in a different method measuring the static patch pressure.telcoman wrote:
http://forums.g35club.org/zerothread?id=307229
Since the replacement purchase at 47k miles I now have 90.7k or almost 44k miles on the replacement OEM Bridgestone Turanza's 235-45-18
I have been rotating this set every 6k miles or every other oil change. (28 oil changes thus far)
I checked the tread depth this morning and all are at 6/32
I keep the tire pressure at 37lbs when cold
I will probably replace these tires prior to next winter at which time I will have over 100k miles on my G
Telcoman
I just reached the 50k mile mark today on my tires with 6/32 left on all four tires.telcoman wrote:
Telcoman
SPAM!
Just curious how the tires look now. I would think you would need to continue your experiment into the 10,000 mile range before a sizable difference in tire wear can be measured.awdjdmtalon wrote:Ok sorry for the long delay in updating. There was no change on the last update so I waited a bit longer this time.
Ok it has been just over 3 months and right at 1800 miles.
No flaming here...awdjdmtalon wrote:Ok folks. It has been 15 months and 11000 miles +/- 200.
I checked tread depth today. And the results are............
RR O M I 5/32 6/32 5/32
LR 6/32 6/32 6/32
I have run the tires at 34 psi for the last 10k miles.
I think from the results, that 35 psi is 1psi too much to get even tire wear.
90% of my driving has been city stop go. The other 10% was hwy and mountian driving.
Let the speculation and flaming begin.
Another updatetelcoman wrote:update
Decided to replace the tires at 99930 miles after 52715 miles on them with 5/32 tread left on each tire.The Infiniti dealer had a sale buy 3 get the fourth free on Bridgestone Turanza 235-45-18 tires till the end of the month. i decided to go for it.Rotating tires every other oil change at 6k miles greatly extends the life of the tires. I probably could have gotten another 5 to 10k miles but with winter coming to NJ soon I took advantage of the sale price.
Telcoman
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
