Poyzinous »
https://forums.nicoclub.com/poyzinous-u125838.html
Thu Jun 10, 2010 7:23 am
uneven tire wear should only be slight. At about 10,000 miles, about 2/32 of difference in the inner edge and outer edge, but no more. A front and rear tire swap is a good idea to do, followed by an alignment after 10 or 15,000 miles, to keep tire wear even. The brake squeal, if it only squeals a little bit when going in reverse, is nothing to worry about. Its very common but is no trouble. But if you have an 09, its Akebono brakes, not brembo. Still, I'm pretty sure most of us experience a little squeal in reverse only. Even me.
