Qgrappler »
https://forums.nicoclub.com/qgrappler-u270.html
Fri May 02, 2003 3:32 am
Heath
I'm running the stock wheels, which I think are 15"--its a Q45T, 1994.
On the sidewall strength, max pressure question, I see what you are saying. However, when I go back and read the explanations linked to the headings on the tire specs section at the tire rack site, it says that the load rating of the tire is done at a standard pressure for all tires. It also says the mac pressure is unrelated to the load pressure. The way I read their explanation, I would say that the Michelins and the Dunlops load handing ratings were equal, but that the Dunlop can be inflated to about 7 psi higher (15% above the Michelin 44 psi max).
Having said that, I also see a table where they show the relation between the maximum load and tire pressure, and the load rating decreases materially as you lower the pressure from the measurement standard of 35 psi. Now,... I dont know if the decreased load rating means that you'll hit the rim in certain potholes, or that the tire will wear out quickly from overheating and excessive flexing. I suppose both. ....In any case, it shows the importance of keeping the inflation pressure high. I wonder what pressures group members try to maintain in their cars.
