Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Thu Jul 30, 2009 4:39 am
Depends on the tire size you run, not the wheel size.
A tire with a lower aspect ratio on a 16" rim would be about the same diameter as one with a higher ratio on a 15" rim.
Assuming you're going with the same tread width and aspect ratio on the 16 vs. the 15, and you're running a tire 1" taller than what you have, you may see some change. Keep in mind though you're speedo and odo will be off by a small percentage too, and a correction will need to be made to any mileage figures you calculate.
