Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Tue Oct 14, 2003 8:17 pm
"You know your wrong right? A 275 tire on a 10" wheel will give you a bigger contact patch then some 195 tires on a 6" wheel if they're the same compound and tread design....think about it...
Redline"
you ar so gonna make me regulate on your *** if you dont do some searching before saying that. tell you what, YOU think about it. what happens to a contact patch as the tire gets wider? the patch gets WIDER...not bigger, WIDER....search man. please search, i;ve discussed this en infinum allong with c-kwick, grant, nils, and smithsr.....and even q45tech....
a 205-55-16 does have a long contact patch, which benifits ride quality, but lateral grip suffers a bit because it lacks enough width to be sufficiently stable in a turn. you can easily fir a 225-50-16 on the stock wheels, but a 245-45-16 on stock rims is far to wide for the bead to seat properly.
I would try out some yokohama avs ES_100's, falken zeix 512, and if money isnt an option, you could even get michelin pilot sports A/S tires, which would fufill your criterion the best.
if you havent lowered your car over 1.2" you shouldnt(depending on the car) need a camber kit, the stock factory eccentric bolts should do fine.-chet
