BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Mon Jul 26, 2004 6:20 pm
what marshun is saying is that on a stock wheel, to achieve a stretched look, he'd have to run a much skinnier tire, thereby killing his contact path. basically, he'd have to run like a 165mm tire to get a stretch on a 6" wheel.
the reason for stretching achieves a couple things. the most important is that when drifting, the sidewall won't flex as much, giving you better feedback to the road, better control and stability. It also allows you to run ridiculously wide wheels without having to seriously increase power to break loose a tire that would normally fit on that wheel. And lastly, it allows the socalled "drifter flush" to happen, when the lip of the wheel is flush with the fender, it allows the wheel to come out and the tire to stay inside the fender without hitting the fender.
