Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Apr 15, 2006 1:27 am
Unfortunately the speed ratings only apply to near new tires under 8,000 miles and under very rigid in door lab conditions [cool] GOING PERFECTLY STRAIGHT no curves!
Always chose a higher rating than you ever ever ever expect to go especially if you don't replace tires every 8,000 miles.
Always inflate tires to 35 psi cold if you expect to get within 80% of max speed rating.............for example an S tire rated at 112 mph should have 35 psi if you ever hit 89 mph.
On 51 psi max rated tires this gets bumped up to 40 PSI COLD!
LOWERING SPRINGS or just excess negative camber focuses the heat on the inner edge of tire this requires ADDED SAFETY FACTORS BE APPLIED TO TIRES!!!!!!!!!!!!!!!!!!!!!!!!!!!
