chow wrote:Treadwear is wierd and there is no official way to compare them but heres how the unofficial system goes.
The base tire has a tread wear of 100. Just say your tire is rated 200, that means it will have 2x more life then a 100 tread wear tire. With a 300 rated tire it will have 3x the life. Just simple ratios.
true, but because there is no standard that anyone uses, the treadwear numbers from tire company to tire company is 100% useless. its only valid when comparing tires from the same company!
