HAHA, yes, I've heard of at least 1 person who has run 215/45's on their 9" rim ok.sixxdeuce wrote:If it were me I would run 215/45/17's on them. I ran a shop car yesterday with that same size falken azenis st115's on an sr hatch at 10psi and it had plenty of grip.
Partly to run a certain rim w/o having to do spacers to clear the inside strut (usually coilovers), or having to pull the fender too much, or need to have too much negative camber.Luke wrote:Why do people stretch skinny tires on a wide wheel? If i was into drifting then maybe, but it's not practical on a daily driver.
Maybe not practical for you, ive daily driven on stretched tires, full stiff coilovers, 2-way, metal bushings, ect and love it, and there are much much harsher setup 240s being daily driven in socal. People have different ideas of streetable.Luke wrote:Why do people stretch skinny tires on a wide wheel? If i was into drifting then maybe, but it's not practical on a daily driver.
Whatever floats their boat. I of course prefer to have a comfortable ride for my significant other. I'll end up getting another daily driver and use my S13 for weekend fun.sixxdeuce wrote:Maybe not practical for you, ive daily driven on stretched tires, full stiff coilovers, 2-way, metal bushings, ect and love it, and there are much much harsher setup 240s being daily driven in socal. People have different ideas of streetable.
I already planned to roll the fenders, everyone told me they'd fit after that... Have you had trouble like this in your experience? Please explain before i mount tires that won't work...turtl631 wrote:You will probably have a hard time fitting 245/40 in front on s13. You will probably need to either roll your fenders or add more camber than is ideal...or both.
That's my car. And it's really not streched that bad. I've seen much worse. There's no way you'll fit a much larger tire under there without a decent amount of PULLING. And yes the wheel itself isn't flush in the rear, sticks out maybe 1 1/2 in or so. The ride is great in my opinion for a street/track car. It cuts corners very well with no tire or body roll on KTS coilovers. My car is daily driven btw.Luke wrote:This pic here is what provoked my question:http://home.comcast.net/~sirdoc99/DCP_0667.JPG
He said he is running a 235/45/17 tire and that looks really tight. I'm afraid if I got a 245/40/17 it would square the tire out and create a bigger rubbing problem.
I'm a noob w/ tire and suspension so someone clear this up before I spend my hard earned $ on it. Research on forums is frustrating sometimes because of so much opinion and misinformation.
PREACH BROTHER PREACH!solaris22 wrote:PS: If you bought an s13 for comfort of your 'significant other' you bought the wrong car.
solaris22 wrote:PS: If you bought an s13 for comfort... you bought the wrong car.
Hey I love my S13, nothing bad to say about it! Thanks for being helpful. It does look like the 245s will tuck in the back after a fender roll. The front, not so good, i held the tire up in the wheel well and while it was extremely close to the strut, it doesn't look like it would fit even with fender rolling.solaris22 wrote:I sold a 2001 BMW 325i to get back into the S13 game. That's a comforable car. My 240...no so much
You can use the 245/40s. I kinda wish I went with those in the back. Just find a reliable shop to roll and pull your fenders. If they're really good you might not have to repaint your fenders but chances are you're going to have to.
I know this, i'm that much of a newbie I was wondering what's the procedure to pull a fender. I remember reading it involves a torch or something. i'd try it if it wasn't too difficult.solaris22 wrote:rolling is just the inner fender lip. Pulling is rolling untill you get a 'flair' in the fender.
LOL, ok hold on let me read this threadSR_Smith wrote:At full size that picture, it looks as though the tire and wheel assy is actually sticking OUT from under the car, and the tire is stretched enough to bring the shoulder of the tread back in line with the fender.If that's the case then the man to ask is Chmercer.
Thanks, i appreciate the advice. I don't have a lot of experience with suspension/wheels like I do with engines. I'm thinking of just mounting just two of the tires at first and test fitting them on the front. That way if it doesn't work out, i can exchange the remaining two for a more narrow tire. I'll definately try it out now, will I have a lot more trouble on the stock suspension?chmercer wrote:hmm ok before you ship thoes 245s back consider this.
with that suspension (the shock and spring) the tire is going to be fully exposed (ie no tucking) so i severly doubt that you will have any rubbing issues in the rear. unless you catch air or somthing you should be scott free here. you will probably want to roll the inner fender lip (push it up) to take care of any possible rubbing during compression.
in the front, you shouldnt have any problems with rubbing on the fender, but with stock fender tubs, im going to guess that you will rub a little on the liner at full lock. this is just an educated guess since i have an s14.
when looking down at the fender wells from the top of the car, with stock camber settings and fenders, the tire will probably stick out just a *little* bit. this is more of a style thing since it wont really affect much of anything. you will gain a little camber when you put thoes lowering springs on, again a shot in the dark here, itll probably put you around 1.7-1.9 camber. stock on these cars is like 1.6 right? so that might help tuck it in a little closer to the body.
cliffsnotes - i would try it, rolling fenders is an easy/cheap DIY if you have to do that, just get a jack handle or a bat or whatever. should be plenty of adjustment for your needs on the stock eccentric in the rear, and if you really want you can get camber bolts for the front, real cheap, or camber plates, a little more expensive.
