Tire size
VeezEMZ
Car: 06 m35
:wavey: will 235 55 19 tires fit on my 06 m35 sport
Larz
Car: 2019 Q70-L RWD
Welcome to NICO
I believe your car came with 245/40/18 with offset 42 from the factory.
You are going to a thinner tire that has higher sidewalls. The 55's will fill your wheel well by an extra 1.25 inches. It will also cause your speedometer to be off by 5mph. When your speedo says 60 you will actually be doing 65. You will also raise the car higher off the ground which could affect handling and braking. I would recommend keeping the 245 or going a bit wider to 255. As for the sidewalls, I would go up to 45, but not 55. I have 255/40/19 and love the handling and the ride.
Here is a site that allows you to enter the stock numbers on the left and your new choice on the right. Enter 245 - 40 - 18 - 42 in the left column to get the proper starting point. Then play with the right side to see what changes a different tire will have.
https://www.rimsntires.com/specspro.jsp
VeezEMZ
Car: 06 m35
Good feedback and Thank you for taking the time in doing so. I was given these 4 tires that's the only reason why I was hoping to use them on my sport m35 2006.
The00Dustin
Car: 2006 Infiniti M45
If the response that they will fit your rims was correct (I have no reason to doubt Larz here, but I didn't do any research) and you do try to use them, also be aware that you may get rubbing between the tire and wheel well cover during sharper turns.
BlackCat81
Car: 2006 Infiniti M35x
2003 Lexus GX470
They'll more than likely fit, they'll just look really goofy.
