tire size question
captain nismo
Ok. I've searching around a bit, and i've came up short. Does any manufactater make a 225/40/17 Z-speed rated tire that is a good performance and handling tire? I've searched and I've only found some Falken Azenis that fit that this size. Anybody want to recommend some tires?Chris
Doogz
Car: '89 240sx coupe
If you go to the tire manufacters' websites...many of them state that they do make tires in that size, but they are impossible to find. 225/40/17's are hard to find and 225/35/17's are also hard to find but you might have slightly better luck. If you go 225/45/17's then you should have no problem at all, which is what i have decided to do because the other sizes are just too hard to find.
Exar-Kun
Car: 2005 350Z
nitto and falken both make tires in the 225-40-17 size...why do you want that size anyway? the 235-40-17 is much more common...-chet
Dori Dori
Car: Cars of course
or 225/45/17
I had those in S03's on my last car. Very nice.:cool:
pancito
Car: CARS!!!
I to wanted 225/40-17 because is the perfect change from stock 205/55/15, but i didn't had any luck, i went with 235/40-17 from falken. That is the best i could do.
Now i'm in the same hellhole as you with the rear tires i was looking for 255/35/17 but i can't find nowhere and again only FALKEN has 245/35/17 for my 17x8 wheels.
And i know stock is 195/60-15 ;)
captain nismo
Yeah. The 225/40/17 size has nearly the exact same overall diameter. I was looking at putting them on a 7.5" wide rim so I don't want to go to wide in tire width. I don't think Nitto's are sold in Canada, but I could check again.Chris
