continental_drift »
https://forums.nicoclub.com/continental-drift-u33689.html
Sat Dec 03, 2005 11:54 am
your stock tires are 205/55/16, I'd just drop the sidewall and make it 205/50/16.smith and kun are right when they say that its the rubber that makes the traction rather than the inferred section width.
if you're going to widen up, i would go with the 215/50/16. you've still decreased your perceptual sidewall height .21 incheswith some sticky rubber, it will be more effective than a 225/50(which maintains the same approx sidewall as your stocks)...that is, unless you like swaying in the breeze.
hey tokyo, 0 offset is pretty far off from 40mm stock, the higher the offsetthe lower the clearance.
Modified by continental_drift at 2:19 PM 12/3/2005
