Tire Size Question. 2007 G35s. Same size ok?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
btreese
Tire options really suck for this car as far as OEM replacement. Are there any issues with putting the 245/45-18 (rear size) on the front (18x7.5 wheel)
2007 18" sport wheelsFront: 18x7.5 +45mm offsetRear: 18x8.5 +50mm offset
Thanks in advance.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
The best way to find out if certain tire sizes will work is to use the tire size calculator.
http://www.1010tires.com
Put in the oem tire sizes for the car and compare them to sizes you think might fit. If they are 3% +/- difference in diameter, the calculator will warn you it is not recommended. You could run the same size tires all the way around even though there is a 1" difference in width. You may also be able to find a diff front tire size that is within specs of the oem.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
