The distance from the ground to the fender is entirely dependent on your ride height. You could run monster truck tires if you were high enough. However, why not just run properly sized tires? Then your speedo will be functional and you can go lower without rubbing issues.Speckid14 wrote:
You totally misunderstood me. I didn't mean the OD in relation to the speedo, just in the relation to fitment. (ground to fender). I also didn't mean the expected diameter of the wheel (not sure where you got that) I meant the overall diameter Tire to Tire with rim in the middle. I got my measurements off of Nitto website. Those numbers included wheel size. Sorry for the confusing sentences.
I don't care if the S14 tires are a little bigger overall, that doesn't change the maximum capacity of the wheel well (ground to fender). I am curious if I can fit a 25.55" OD (tire to tire with rim in middle) on my S14. I have overfenders 30mm in rear and 20mm in front (only going to run a 245 in front).So will these Nitto's fit?
