TIRE SIZE NEED HELP
TRANCEBOY
Car: Rogue SL
OK .. SO YOU GUYS KNOW I GOT 20S ... NOW FOR TIRE HELP
DISCOUNT TIRE DIRECT TOLD ME 265 35 20
THEN I CALLED ANOTHER PLACE THEY TOLD ME 245 40 20
NOW I SPEAK TO ANOTHER GUY WHO TOLD ME 245 45 20 WOULD LOOK BETTER
SO WHO IS RIGHT >?
IM ADDING THE H@R springs so those might lower a little but i dont want to look like im driving a civic
i spent a few bucks on tsw wheels and want the look of a really sporty suv ... not racer .
I also looked into the continental DWS tire and its rated as a super quiet tire but not cheap.
please help ... ive asked alot of questions and not recieved alot of answers. Please help as you helping me
will help you make proper choises on your own rogues.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
I would go by Eddnogs aftermarket wheel chart for the Rogue.
Hence, I would chose the 245 45 20 which would also be the best for odometer and speedometer accuracy according to Ed. :bigthumb:
Not only that, it would look better according to your tire guy. :dblthumb: :mike
aftermarket-wheel-tire-fitment-chart-t293478.html
TaiLuu
Car: 2009 Nissan Murano LE AWD
2011 Nissan Rogue SV AWD
2014 Nissan Pathfinder Platinum
Speed is measured from transmission wheel so it doesn't effect it.
Your on 20s so the 40 or 35 should be good.
Higher the middle number the more grip you get cause wheel rotates less
TRANCEBOY
Car: Rogue SL
EGGNOG is gonna have to help here. Just got back from costco and the guy tells me that 245 45 20 will fit but might rub ?? By the chart that he posted it says it will fit perfect. The guy suggested a 245 40 20 but says if i add the h@r springs my ca will be rubbing all over. Im so comfused
motaro9424
Car: 240sx convertible
maybe this help better.
Use this tire calculator..
http://www.discounttiredirect.com/direc ... reMath.jsp
philipa_240sx
TRANCEBOY wrote:EGGNOG is gonna have to help here.
Eddnog hasn't posted here in almost a year (Oct 2010). I doubt he will be checking the forums.
Costco is NOT the place to get advice on tires. They have no clue on upsizing, fitment , suspension mods etc.
A piece of advice: Find a reputable tire shop that knows what they're doing!
Example:
On my '03 Altima, I went from 205/65R16's to 245/45R17's with 8" wide rims. I also upgraded to Nismo S-Tune suspension (~1" drop). These are major changes in tire and suspension from stock!
Guess what? No rubbing issues whatsoever! The tire shop was the key here... they selected the proper rim size, offset and tire width.
Return to “Rogue Forum”
