Tire size help to make it FLUSH!!!
NisanS13turbo
Car: Diamond White 91 Nissan Coupe
The wheels are 17x9 for F/R and they are 35+ offsets. What would be the
tires size to make the rear and front to sit flush with the fenders and rear
quarter? THanks much guys
AkademikONE
It won't really be flush, unless you get a lower offset, or a spacer.
Juujai
for the fronts you'll probably need a 15-20mm spacer. depends on what camber and if you wanna roll.u can fit anywhere from a 225-245 pretty easily.
chmercer
flush tires with the fenders is weak. and thoes front wheels are gonna need a spacer to clear the shock unless you run positive camber.
NisanS13turbo
AkademikONE wrote:It won't really be flush, unless you get a lower offset, or a spacer.
What is the perfect offsets for the s13 saying that i already have a 35+
offsets and what would be the spacers in front and in back. Thanks
AkademikONE
Well, what rims are you getting?
Go with a 17x9 with a +12 for the rear
What suspension are you running?
NisanS13turbo
AkademikONE wrote:Well, what rims are you getting?
What offsets is this 240sx running then? Because i want my to look like this.
AkademikONE
The offset of that rim depends on the width. Looks like a 17x10 with a +12 offset
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
The fender is also rolled and it has negative camber. I would guess... a 17x10 also with a stretched tire.-Alex
Juujai
i think that red car really needs wider fenders... not a fan of pull.
if you really... wanna make it look like that just get any wide wheels x9-x10 or so with low offset with +15 or lower.
if it sticks out past the fender then pull your fenders.... or "add more neg camber"
