Tire Size Help!!
Fancy
Car: S13 Coupe
Got some...waiting in the mail for... some Fn's 17x9 +20 and need help with some tire sizing. On lowered springs and struts right now, but waiting to get a good price on coilovers, so I want to pick up good sizes, so that when I switch to coils I don't have any issues with rubbing. Going to need to roll the fenders as well when I switch, curious as to whether I should or should not pull the back a little when I'm doing. Any input helps, thanks in advance.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
http://www.rimtuck.com/thumbnails.php?v ... =20&sort=1
This guy is using 225/45. I would probably run a 235/40 if you were stretching.
The perfect fit tire for a 17x9 is a 255/40.
simmode1
Car: Red '95 S14
speedeast wrote:I would probably run a 235/40 if you were stretching.
That's what I would do. It's a very subtle stretch. Very tasteful, IMO.
Fancy
Car: S13 Coupe
Alright cool thanks for the help. I checked rimtuck after I wrote this. Do you think I would need to pull the back at all with a 235, or sufficient with a roll?
speedeast
Definitely roll, you might not need to pull.
simmode1
Car: Red '95 S14
speedeast wrote:Definitely roll, you might not need to pull.
:werd: If you're on coilovers, you can dial in a little negative camber to get those tires further away from your fenders and also improve handling as long as you don't go too crazy with it...
Fancy
Car: S13 Coupe
Yeah, that's what I figured. Thanks again for the help. Now just have to wait patiently for them to arrive. :ohno:
