Tire Size for some big wheels
nab911
Car: 93 Nissan 240SX SE
Well my wheel plans have changed once again . Instead of the 17x7's.... i found a deal on some 18x8.5F and 18x9.5R's. Before you flame me i dont care about performance at all... i wouldnt be buying these pieces if i was. Its for my s13 vert and the thing says its made for s13's. Anyways.... what size tires do i need to fit on 9.5" wheels? Im thinking a 255 would get it but my friend said i will need bigger. So im thinking 225-235 up front and 265+ in the rear. Sound about right?
Also do i need to worry about sidewall height because the car is not lowered at all.
Nick
nismofly
Car: 89 Nissan 240SX Hatch
what offset are the wheels?
nab911
hannibal
Car: Red Line to Glenmont
I think those will hit the struts in front. You need a lower offset or use spacers. Who said they were made for the S13? Did someone actually have these on their car?
225/45 and 255/40 should give you a nice stretched look.
chmercer
255 in the back is fine. thats oem tire size on nobles IIRC
nab911
im worried more about the tires fitting the wheels. I have 2 wheel spacers and i can get more.
nab911
Ok, i have a chance to get some good tires really chep but i need to know if putting 245's in the front, and 255's in the rear is a good idea?
SoCalSilvia
Car: S14- 1995 240sx
i doubt you can fit 245 in the front on s13. run 225 in front and rear too. or if you want staggered tires 235/245 in rear.
chmercer
you can run 255 in the front if you do it right. and yea thats what i said 255s will fit 9.5s fine. itll almost be a square sidewall, maybe a little stretch depending on the brand of tire.
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
i have 255's on my 9s at the front. Yes it looks like a square sidewall...
AP Autosport
Car: 89' Sil40 w/sr20det
I just put on some 9" wheels all around with some 235/40 on the tires and they fit fine. I had to flare the fenders to get them to fit, but I think I could fit 255's if I wanted.
nab911
You flared your fenders.... what was the offset of the wheels?
POOPmouth
Car: The Devils pimp ride
Bomexs13---- those are 19s so niceif thats it correct -let me know -if not then plz correct me ---thansk
