tire size for 16x7 and 16x8?
babowc
Car: 240sx
well guys,i just got a bangin' deal on some 16x7/8" enkei racing S wheels.
the problem i have is..
would 205/55 or 60/16 look about the same on both?i dont want the front to be bulging out and the rears square or worse, stretched...
i was thinking about getting separate sizes for front and back, but i realized i couldnt rotate them.., i'd like to have the ability to rotate them since i'll be running these as a daily set.
if anyone knows.. let me know,thanks.
mike
nismofly
Car: 89 Nissan 240SX Hatch
you should be running 205/55/16 front and 225/50/16 rear
running the same size tire all around on those wheels would create the situation youre talking about
tamdo714
Car: 240sx
sorry for thread jacking but i've been reading some stuff and getting confused. why do you want smaller side walls on the rear? you say for the front 205/55/16 and the rear 225/50/16? thanks
nismofly
the middle number is the aspect ratio
its the size of the sidewall as a percentage of the width
so the fronts would have a sidewall height 55% of 205, the rears would have 50% of 225
nismofly
btw dean caught something, i had a brain fart before
you cant rotate staggered wheel sizes anyway, so why worry about staggered tire sizes?
babowc
Car: 240sx
oh,i was thinking more in terms of running same sizes and rotating the tires alone..not the entire wheel.anyways.. a problem came up.
i just recieved the wheels and one wheel is bent and has a ~1/2" of crack along the bend.
definitely going to be taking care of this issue first.
Eddie
Car: 1995 240sx se
nismofly wrote:the middle number is the aspect ratio
To add on to nismofly's info. 55% of 205 ~= 50% of 225. The side walls are practically the same thickness.
(.50)*(225)= 112.5(.55)*(205)= 112.75
nismofly
babowc wrote:oh,i was thinking more in terms of running same sizes and rotating the tires alone..not the entire wheel.anyways.. a problem came up.
that would cost a TON of money
as in, youd save money by getting new tires halfway through their life over doing it that way
babowc
Car: 240sx
oh lolalrighty..they'll last me AT least a good 20k.. so im fine..but still i need to take care of the bend and the crack..
howmuch do shops usually charge to repair a rim?also.. enkei racing S are.. i suppse cast aluminum(?).. so dont know how its going to be..
nismofly
the bend wouldnt be a problem...$100 or so
but the crack might mean you cant use that wheel
babowc
Car: 240sx
hm..if so.. ill be getting a refund for these.. -_-damnit..i suppose they cant be patched up or something if they're cracked...
