Tire size adjustment 08 G37S
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
hammertime
Car: 08 G37S 06 BMW M3
I am going to use 19 x 8.5" front wheel with 2453519 tireand 19 x 10 rear wheel with 2753019 tire, front and rears will have 10 mm spacers, I checked and I have acceptable offsets on the wheelsIs this profile too small for this car? I have this same setup on M3.I checked the tire size calculators and it doesn't addres this profile
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
go to http://www.1010tires.com and put in your oem sizes and compare them to the new sizes you want to run.
hammertime
Ok, according to their calcs, the upgrade should be 24540 and 27535the reasoning is brake failure, do you really think it makes that much differance?
RED_DET
Vendor
2011 Infiniti G37x
It will make a difference when the difference is 3% or greater. It may throw off the vdc.
hammertime
so I ordered 2753519 for the rear and I'm putting the OEM 2454019 rears on the front
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
