tire size? .................255-70-16 on a 2001 path
bigballerhanh
Car: 2001 nissan pathfinder
I have an 01 pathfinder with stock tires size 255-65-16......Will changing the tire size to 255-70-16 make a big difference at all...if so what specific kind of difference as far as handling, mpg, rough/smoother ride? I was wondering because my buddy has 255--70-16 tires for sale very cheap and I need new tires...Will it be worth buying them?
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
You can check on this link to see the difference in the two tires.http://www.miata.net/garage/tirecalc.html
K03sport
Car: 04 Pathfinder. My first Nissan was a '72 Datsun 510 Wagon.
nope, there shouldn't be too much of a different, but it depends on the tire manufacture as well. What tires is your friend selling? Do you know the load rating? Not all tires are created equal even if they look equal.
Remember, the 65 or 70, in the tire size is the sidewall height's aspect ratio to the tread width. With a 255mm wide tire, you are looking at a sidewall height of 165.8mm (6.5") and 178.5 (7") respectively. So, the 70series tire will be about an inch taller than the 65series tire. Again, this will depend on the tire and who makes it.
You will still air them up to the same pressure - 30-33psi, depending on load. I think the door panel sticker says 30psi, but that is probably for comfort. I usually go about 10% above and if I know I am going to be carrying a heavy load in the back, I usually bump the air up to 38-40psi in the rear. Then of course, I air down when I am done.
The bigger tire will probably be a bit heavier, but shouldn't affect overall mpg or ride. Your speedo might be affected some as the revs per mile will decrease.
How used is used and how cheap is cheap?
bigballerhanh
4 LT255/70R16 COOPER DISCOVERER ATR TIRES FOR SALE -125.00All the tread is at 7/32nds..............is it worth it or not?
K03sport
bigballerhanh wrote:4 LT255/70R16 COOPER DISCOVERER ATR TIRES FOR SALE -125.00All the tread is at 7/32nds..............is it worth it or not?
That's a good question. 7/32 left is about 70% of new (11/32???). $125 is about where the stock tires start, and that is for just one, so getting 4 for the price of about one isnt' too bad, even with most of the tread left.
If you are concerned about if they will work or not, mount on a wheel, if you can, and do a test fit. I think you will be fine. There are guys here running tires larger than stock with little to no lift, so I don't see a problem. The worst thing to happen is they don't work and you sell the tires as-is yourself for $125-130, and try to get something else.
In the time you run these out, you can be saving for NEW tires. You should be able to get at least a year or 2 out of them.
We got about 4 out of the stock Duelers, but then again, that was only about 22k miles....
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
it will rub in reverse while turning and also when fully fully loaded over big dips, atleast mine do
