tire sensors
Nissan 350z / Nissan 370z general community discussion forum
coolwray
Car: 2006 350Z
I have aftermarket rims and my tire sensors only work part time and i am interested if anyone else is having this problem and if there is a cure so they will work all the time
Tennz
Car: 05 350zr
They work on a 30 second cycle.
mec011
Car: 1995 240sx 5spd Base & 2004 350z 6mt Touring
If i understand, you mean it works for a while, then cuts out? One of my sensors (on the stock rim) works for an hour or so and then cuts out, the dealer said to bring it buy next time it happens and they can tell quickly once it's cut out what's wrong. Maybe they can tell you? (if it flashes when it cuts out, it should flash in a pattern to tell you what sensor is having the problem.)
Return to “350z / 370z Discussion”
