FHoffert »
https://forums.nicoclub.com/fhoffert-u124959.html
Mon Jan 23, 2012 7:19 am
For any Nissan owner with TPMS, and a need to reset the TPMS light, a couple individuals have posted a procedure describing how to put the TPMS system in "Learn Mode" by using a short piece of wire or a tool that can be found described on the web and sold at Amazon or many other retailers under the name "OTC-3831", or "OTC 3831" or "KTI 71985" or "KTI 71981". I just want to confirm that I purchased the tool "OTC 3831" on Amazon for $ 21.00, it is a little trigger like device with a male plug which matches Nissan' TPMS test connector under your dash (in different places on different models), on my 2007 Versa Hatchback it was just above my hood release and gas door release, and an allegator clip (providing a ground), plus a "jumper" or converter which I needed to use since my Versa's TPMS test connector was a male vs. femail connector. But, it worked perfectly as described!! I actually was successfull in getting the BCM to relearn and register all sensors including one that had recently been replaced by Sears when I purchased new tires and they did not know how to do the reset. My warning light had been blinking for a minute and then going solid (an "error" or system problem indication) with each start-up, so I set my front left tire to 36 psi, the front right to 33, the right rear to 30 and left rear to 27, connected the reset tool, clicked it 5 times within the specified 10 second window, and the TPMS light began to blink slowly indicating it was now in "relearn mode". I then disconnect the allegtor clamp, started my car and drove it for about 2 & 1/2 to 3 miles at 30-40 mph, and the light finally went out!! There is actaully a Technical Service Bullitin that I found on the Web that was issues in August 2007 announcing the creation of this handy little reset tool, complete with pictures and instructions, though my TPMS connector was in a different locations.
I forget the actual search string I used to find the Technical service bulletin I referenced, but a search on the following should get it for you "TIPS Technical Service Bulletin #2007-002"
