tire scraping noise going over bumps
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
dvdmccll
Car: 2006 G35 sedan
When I go over small bumps, I hear a sound like the tires are scraping the inside of the wheel well- it's on the front only, and it started as soon as the weather got cold. Any ideas?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You are hearing the tension rod bushings. Common issue especially on the G35 in cold weather.
dvdmccll
Car: 2006 G35 sedan
Do they need replacing? I have an appointment at the dealership Tuesday. My advisoar says adjustments usually aren't covered by the extended warranty, but replacements might be...
RED_DET
Vendor
2011 Infiniti G37x
Depending on mileage, they may need to be replaced. Mine have always done it in colder weather and I have 60k miles on the chassis. I have not replaced them either.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
