Rogue One wrote:General rule, rotate tires at every oil change. Replacing the oil filter is part of having your oil changed. They'll offer to do the engine air filter and the cabin filter. Tell them no, as these are easy DIY, and you can get them for about half of what the dealership will charge. There's instructions on this form. Use the
SEARCH feature.
Every oil change. I'm bit excessive if you don't drive much. Like I said I have only 7000 miles and it's been a year. I thought it was usually 10k
Also. Are their any other one year services that should be done. She said at Nissan only conventional oil change. Synthetic isn't needed cause my rogue has always had conventional which needs to be changed ever 6 months or 5000 miles
