naed240sx wrote:
Uhhhhhhh NO. 215/35/18 is tiny. It's an inch shorter in height than stock size.
My bad! 225/35 R18, my aspect ratio is good just not my width, i was trying to say he will definatly need a low pro tire. that tire should put you exactly on stock diameter, the 215 35 would be a little less than an inch different (smaller).
insanitykouki wrote:i honestly dont know the offset of the rims as im just asking in general. id assume id obviously want a negative offset so that i could fit wider rims, correct? im fairly new to the whole situation rather get it right the first time lol.
The offset is very important when deteremining fitment, especially with wider rims they will rub your suspension components. You will need a serious fender roll (and IMHO flares) to pull off a neg offset. You are probably looking for a +25 or something ( depending on whatv you like your stance to look like. I don't like my wheels to stick out far beyond my fenders, but most will disagree with me.
