Larz »
https://forums.nicoclub.com/larz-u216291.html
Tue Nov 03, 2015 8:48 pm
I have always had Michelin pilot super sports until my last tire change. They are wonderful tires, grip like a cat on a carpet pole, and ride as well when worn down as they did when new. As for installing high performance tires, I only have the 35HR engine and I notice a big difference in turning, stability, high speed handling, wet traction, and ride. I switched to the Hankook Ventus S1noble2 tires (255/40/19) and they come as close to Michelin as is possible. The Ventus are classified as Ultra high performance A/S. No disappointment at all. However, no idea yet if that performance will last over the miles like the Michelin do.
In general, the touring tires will be quieter than high performance tires and have less grip - though it isn't clear if that "less grip" affects normal driving or if it just exists at the test track.
The HP tires have stiffer sidewalls, a different rubber formula, and result in harsher ride over bumps compared to grand touring, etc. However, on a nice, level motorway, the Ventus and the Michelin provide a ride like a magic carpet, but you still feel a definite connection to the road.
