Larz »
https://forums.nicoclub.com/larz-u216291.html
Fri Nov 20, 2015 9:14 am
I do not use or trust Consumer reports. They are definitely NOT bad people, just inaccurate. For instance, some of the tires they call 'performance' are not performance tires - they are 'touring' tires. The best way to search for tires for any car is Tire Rack. Tire Rack allows you to search for your specific vehicle - it lists the factory tires and gives you options based on what type of tire you want - even has a 'decision guide' that tweeks your search based on road conditions, weather, etc where you live.
I always use ultra high performance all-season tires for great grip and all around improved performance over touring or regular tires. After choosing the tire that best suits you, there are test videos comparing that tire with other brands in the same class. They also list customer reviews from people driving your car or a similar car (Lexuis LS, Mercedes Eclass, etc. That way you get plenty or ACCURATE info on the exact tire you chose.
Personally, the Michelin Super Sports are the best but pricey. I always used them but last year I changed to Ventus S1noble2 tires and could not be happier. They come closer than any other brand to the Michelins in performance and grip, but are significantly less expensive. Tread wear is as minimal (so far). The only comparison I can't do yet is the performance of Ventus Vs Michelins at low tread because my Ventus are still near-new tread. Michelins always perform as well as new even with low tread. Too early to tell if the Ventus can do that. Lots of members here like the Continental DWS but according to tire rack, they have less grip and less connectivity to steering input than other brands. Pirelli make an all-season that is rated very well for our cars.
My current tire: Ventus S1noble2: 255/40/19 on 19 X 8.5 +40 wheels. A bit wider than OEM with great grip in rain, gravel, deep water and even 3-4 inches of snow. I think there are pics in my sig below.
