Tire Rack, Help Me!!!
Phax
Car: Control dynamics
I need new struts and at least two tires to make my car safe again. I have an S13 with Eibach Pro-Kit springs, and need four shocks. Ideally I'd like some KYB AGX's.
As far as tires go, anything that is under $125 a pop. Can I get Bridgestone S-03's for that?
I just checked out the TireRack page. There are Eibach alignment kits for $25. What's the deal with those? I haven't had any problem getting my car aligned in the past, even with super short kg/mm springs. The car rides much higher with the Eibach's. They're probably unnecessary in my case, right?
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
The Pro-Kit should not require an allignment kit, only the Sport Line Kits. The tires will depend on what size you are running. I'm on the way out the door right now but if you give me a call after 8:00 a.m. Eastern tomorrow I can go over the options for ya. Thanks.
