yep, thats why my 225-45-17's are on a 7.5" wheel..the measuring and "ideal" width for my tire
it is, for lack of a better term, exactly flush mounted, with a slight roll of the edges on the trear surface.
Anyways, both smith and GRant are vastly knowledgeable(probably more than me!) about these things, and posted good points.
if the tire is too wide for the wheel(by this definition I dont mean it;s within the approved rim range, that just determines if it s'safe') and spreads out from the sides, it will concave a bit on the wheel(or is it convex? the domed side would be up..) and cause handling issues, but would, arguably have a slightly wider contact patch than the proper sized tire...for instance
moutning a 245-45-17 on a 17x7.5 versus a 225-45-17, sure the 245 is wider, but it will bulge a bit and not handle the stress as well, IMO.
likewise mounting a 205-45-17 or something on my wheels would cause the shogulders to round out prematurely and stress the bead quite a bit in the opposite way a wide tire does, this leads to a more "progressive" feel in some situations, and makes drifting the tire a bit easier since its progressive and will seat the bead stiff enough the tire will not roll(sidewall roll) usually speaking.
hopefully I didnt screw any of that up
-chet
