spankme234 wrote:I just bought i pressure gauge and a couple of my tires were real low like in the low 20's.
That is dangerously low for a Q (since this is the Q45 forum, that is what assume you have.)
spankme234 wrote:My sidewalls say 40psi is the max but i only filled it up to 32 psi. What do you guys reccomend for the best fuel economy?
I used to set my Q's at 35 to 36 psi all around on 44 and 51 psi max tires. Currently, I use 36 psi on all tires on my M45. Cold pressure, measured in the garage in the morning before the sun hits the tire, of course.
Note that I have not seen "40psi" max tires in a long time! How old are your tires? Is the load index safe for a Q (you need at least 95H or 95V rated tires)?
Z
