zgoug »
https://forums.nicoclub.com/zgoug-u130428.html
Fri Nov 27, 2009 7:44 am
At 35k miles I replaced the OEM Eagle RSA's, with Dunlop Signatures. At 4k miles steering wheel vibration occured at at 60mph. Took back to tire shop, rotated, rebalanced all 4 tires - still had vibration, though at 45mph. Tire shop indicated there was also an odd wear pattern in the center of the tread. Tire shop advised to drive 1500 miles and return for inspection - they rebalaced again and used different type weights. Most of the vibration went away, however there is a noticeable increase in tire noise, especially at 45mph. Car was aligned (4-w) when new tires installed, also visited dealer and they checked out suspension, all OK.Any ideas? Could the belts be shifting in the tires?Thanks
