tire presure
Nissan 350z / Nissan 370z general community discussion forum
nik..
Car: 350z hr roadster
what the best tire pressure for Z stock tires 18'/225 front 18'/245 rear what do you recommend ?
PalmerWMD
Car: 2004 350Z
it depends a bit what you have in mind for driving.
I do 38 psi up front and 36 psi in the rear which works for most situations.if you drive mostly in town and have female passengers keep it a couple psi less.
Fred...
nik..
driving and turning fast as i can ,i have now 32 fr/rr isn't it low enough anyway ?
car nut
Car: GT500.
33-38 psi is good for almost any tire. Lower pressure can negatively affect mileage and handling, but higher pressure can give too harsh of a ride and increase the risk of a blowout.
PalmerWMD
Car: 2004 350Z
nik.. wrote:driving and turning fast as i can ,i have now 32 fr/rr isn't it low enough anyway ?
thats definetly a bit low.bump it up and remember the front always get a couple extra psi.
I think you will enjoy your crisper turn-in.
Fred..
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Definitely low.
In the summer I cold inflate to 32psi (it heats up to 36-38 psi after a few minutes), and in the winter I bump the cold inflation to 35 psi (measured in the semi-cold garage) so that when I get outside it doesn't drop low enough to set off the TPMS.
nik..
so you suggest me 2 psi more in the front is is that correct ?
PalmerWMD
Car: 2004 350Z
Nik,
all 4 tires should get more pressure.I suggest 36 in the rear and 38/39 in the front
Return to “350z / 370z Discussion”
