flyvmc wrote:I just bought a used 2004 G35x. Someone put over 40 psi in the tires and I can't get the tire pressure warning light to go out after reducing the airpressure to the suggested 30 psi. Should I have the ECU reset?
Mine came on Monday morning. I checked the pressure in all four tires and they were all at 35lbs. After I made an appointment at the dealer for today (Saturday) the light went out on Wednesday so I cancelled the appointment. If you've got 35lbs in all four tires ( use a good quality dial pressure gauge & not the ones at the gas station) & the light does not go out it is probably a defective sensor which the dealer can locate.
Telcoman
