szh »
https://forums.nicoclub.com/szh-u149.html
Tue Dec 12, 2006 10:46 am
Definitely worth getting a good tire pressure gauge - either digital or analog, although good analog ones tend to be expensive.
Also, I strongly recommend keeping the tires at or above 36 psi ... the mftr recommendations tend to be a bit lower than I like, unless you check and adjust daily!
Typically, tires will drop 1 to 2 psi every couple of weeks anyway, so erring on the high side (like 36 psi) will give you a bit of leeway till you check again.
Z
