RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Mon May 11, 2009 5:16 pm
I was considering it in my 116WHP KA, for during drifting. But then you have to ensure that you wont run out in only a run or two and have a way to refill it at the track. But now that I have 200+WHP I wouldn't want to run water any way. Less traction= less smoke
Unless you ran bleach. That was another thing I wanted to try. Maybe I'll try it this year....hmm. RB20DET+used tires+bleach = super smoke?
I'm now considering it for after run spray down to drop tire temps.
But getting back to actually using it, you'd need a gallon or two or more, and with a tank that size it would have to be tall or low and wide and use baffles. I was thinking of sealing the spare tire well and adding some plastic baffles on hinges, with a windshield washer pump on one side....
Yea Ive put some thought into it...
As far as the stretch, I was talking about just getting a wider rim. In the context of same size tires stretching wont make much of a wear difference. Yea using a smaller tire will usually be cheaper.
Speaking of that, I'm going to order some 16x10 25-30offset from diamond racing. Maybe a pair of 15x10s too. I like my rear tires not to move at all, its a lot more consistent with the big sidewall tires I get from work. IE 205/60/15s and 205/55/16s and 225/50/16s.
~Alex
