OK, I shall Give that a Shot.
I recently, had some issues with some hesitation and sputtering at lower RPMs below 2000.
I have noted that My gas mileage seemed to drastically improve after switching the Autolite APP3924 Platinum Plugs out for the correct NGK PFR5G-11 Laser Cut Double Platinum Plugs at nearly $14/plug which got a lil pricey for the 6, But that's what the factory service/shop book in the trunk calls for. I can honestly say that I have seen some strange spark plugs in my day, But I had never seen Spark plugs like that with the Fine Point electrodes. According to the AutoZone employee, that its for precision firing and of course that this Z-Car (VG30DE) engine requires in order to operate optimally with the best performance and gas mileage. Of course my ears perked up, Hell Anything that saves gas gets my attention with this car.
Another thing that really seemed to help, And I personally think was the main culprit in this hesitation escapade; was to thoroughly clean the MAF (Mass Airflow Sensor) with a can of CRC Mass Air Flow Sensor Cleaner at $8 for the 16 oz. can...Which beats approximately $200 for a replacement Sensor. Of course I used the entire spray can to clean my sensor.
Although It wasn't instantaneous after changing the plugs out and cleaning the MAF sensor for the engine to smooth back up. I had to let her idle awhile and drive her some for her to gradually smooth up to actually better than normal operation.
But thanks for the information on the tire pressure, again I will give that a shot. Hey, anything to save a few dollars on the Premium ONLY Gas, I am all up for.
