tire pressure
Toms240420
Car: My car
i cant seem to find anything on recommended tire pressure anywhere. does anyone know where i can find this info......im runninng 195/60 in front and 215/65 in back. thanks
SmithSR
Car: 240sx
Play around and see what gives best results. 32 is common for the masses. 35 is usually max pressure for the p-metric tires.
Other tires, you'll commonly see 44psi max inflation. Some 50, 51.
Try 32f/r, then 35/3535/32etc....
I'd say most people will tell you 32f/r is fine. Tune yourself into how the car is handling, and adjust as you see fit.
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
:yesnod 32 is a good place to start. That's cold pressure. The stock pressure is going to be too low for most folks' taste. You'll find better stability at higher speeds and in corners.
Exar-Kun
Car: 2005 350Z
I seem to prefer mine at 33 front and 35-38 rear, depending on weather.-chet(sometimes I run 35 and 38)
