Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Sat Sep 05, 2009 3:29 pm
There's a sticker on the door. That's a good starting point. If err, err on thehigh side. If you go too low, you can uneven tire wear (on the outsides), less overall tire life (tire is running hotter) and bad gas mileage. If you go too high, you get uneven tire wear (on the middle), maybe a bit better tire life (tire isrunning cooler) and better gas mileage. Got the picture?
Invest in a tread depth gauge and measure the tread depth at the beginningof every quarter. Write it down in your owner's manual. Adjust pressures asappropriate.
Oh yes, you might get better handling at the extremes from the higher pressure.
