EdBwoy wrote: ↑Thu Jul 26, 2018 12:54 pm
Gene Ln wrote: ↑Thu Jul 26, 2018 4:25 am
... came across a way on older G's and Nissans to manually put the module in learning mode so I tried it and at last found success........
Glad you got it sorted out Gene. Do you mind sharing a link to the procedure you used?
Not a problem, here is where I found it.
https://g35driver.com/forums/wheels-tir ... ols-2.html
and a recap if you don't want to follow the link and do a bunch of reading..
Start by checking if the vehicle is equipped with a TPMS connector (1 wire connection / white connector) linked to the OBDII electric wiring underneath the dashboard (figure 1, left - note that the following example applies to a 2006 MURANO).
Procedure:
1. Use a jumper to link the TPMS connector to ground (figure 2).
2. KOEO
3. Momentarily disconnect and plug back in the TPMS connector (5 to 6 times)
4. The TMPS warning light will blink when the system starts initiating.
5. Start the reset procedure with the left-front tire, then the right-front tire, then the right-rear tire, and end with the left-rear tire
6. Once the system has completed the reset procedure, the TPMS warning light on the dashboard will automatically stop flashing
This method assumes you have access to a tool to wake the tire sensors if you don't have access to that equipment you can manually wake the sensors by doing.
1) set different tire pressures in each wheel: RF to 34psi, LF to 31psi, LR to 28 psi and RR to 26psi;
2) start engine;
3) perform the OBD3 procedure to reset and put the tpms into learning mode - tpms warning light should be blinking;
4) drive vehicle around at speeds greater than 40kph until the tpms warning light stops blinking and turns off. Note a short time later, the tpms warning light should go on and stay on (since one or more of your wheels will be lower that 28psi);
5) disconnect the wire from the connector; and
6) reinflate the tire pressure to spec. and drive around until the tpms warning light turns off.
