Thanks for the info.elmo14226 wrote:I have no experience with TPMS, but I would recommend calling TireRack.com and getting their recommendation. You need to find sensors that are compatible with the Rougue and that will fit your wheels. Their number is 1-888-541-1777
Here is a link to a general discussion: http://www.tirerack.com/tires/tiretech/ ... 44#sensors
--------> READ BEFORE CREATING NEW THREAD! <--------Purplerogue13 wrote:So I just got 13 Rogue and bought another set of tires for it I'm pretty sure they do not have a pressure sensor in them is this something I have to go to the dealer to have to be put on or can any mechanic put them on? Thanks for the help
Tire rotation and TPSelmo14226 wrote:I have no experience with TPMS, but I would recommend calling TireRack.com and getting their recommendation. You need to find sensors that are compatible with the Rougue and that will fit your wheels. Their number is 1-888-541-1777
outtolearn88 wrote:Hello, Has anyone found a better price than the Dealer ?
Was looking into getting a second set of 4.
Thanks Everyone
That information you need to get yourself by reading the ID's directly written on sensor, using a TPMS activation tool to read the sensor. Another method is to use a scan tool and read what the BCU has stored for the ID information.outtolearn88 wrote:Hi Dave08902, No I don'tMaybe someone here can help out with that information ???
Thank you for your input.
We have an incredible SEARCH feature on this forum. Merged with existing thread.sh442olds wrote:hi all bought new car
has oem aluminum rims and bought oem steel for winter so i can run snow tires
cant get straight answer from dealer on sensors want to put in new but dealer said to switch over from aluminum rims
any ill effects of not installing tpms sensors at all
thanks scott
Your Rogue's on-board computer will read the output from the sensors, not the rims. In order for the newer system in your car to work correctly you're going to need to use the sensors designed for it, not the ones from the 1st gen.VBitter wrote:Ok I did further research and those rims came off a 2012 Nissan Rogue SL. Its showing nissan part # 40700JK01B. But the Rogue I have is the newer version. 2014 and the Part # for my car is 407003VU0A. I want to use these older 18 inch rogue rims on my newer rogue. So my question is do I purchase tpms sensors for my 2014 rogue or the ones for the 2012 Rogue?
Listed for use on "Nissan". You'll need to confirm if it fits your Rogue.phmichel wrote:If anyone wants an extra set of TPMS sensors, I found these on Amazon. Best price I've seen for a set of 4:
https://smile.amazon.com/Raomdityat-Pre ... sor+nissan
